Just hit 60k!!! What 60k service to do?
RE: Just hit 60k!!! What 60k service to do?
ORIGINAL: the_most_wanted
02GT 5spd...
should I change the tranny fluid?
also what about the rear differential oil (i think thats what its called)
02GT 5spd...
Here is a guide for scheduled maintenance at 60,000 miles for a 2004 Mustang GT:
Present Service:60,000 Miles
[ul][*]Change engine oil and replace oil filter (up to 5 quarts of oil)[*]Inspect and lubricate all non-sealed steering linkage, ball joints, suspension joints, half-shafts / drive-shafts, and u-joints[*]Inspect automatic transmission fluid level (if equipped with underhood dipstick)[*]Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system[*]Inspect complete exhaust system and heat shields[*]Inspect engine cooling system and hoses[*]Perform multi-point inspection[*]Replace cabin air filter, if equipped[*]Replace engine air filter[*]Replace fuel filter[*]Rotate and inspect tires; check wheel end play and turning noise [/ul]
ORIGINAL: BADSEED
mines at 61K im gonna be changing Plugs, radiator flush, air filter, fuel filter, brakes are still from the factory, tires, belt and a couple of sensors
I would also flush the power steering fluid at maybe 80kmi or so!
