A/C ambient temp. switch
Old Mar 17, 2007 | 04:43 PM
2003GT100's Avatar
2003GT100
Default A/C ambient temp. switch
Forgive the stupid question... I just picked up the GT 2 weeks ago and don't know much about it yet. This forum is helping and is very helpful as everyone knows...
Does anyone know if the 2003 GT has a ambient temp. switch that disables the A/C system in cold weather...say below 45 degrees? I tried the A/C the other day (ambient temp. of about 45-50) and it seems very weak... Does anyone know if the A/C system is weak in the Mustangs and that could be the issue? It doesn't seem to be blowing cold air at all. Just like 45 - 50 degree air. From my limited experience with A/C systems, most work on/sense the ambient temperature and will only achieve a temperature differential (between the air blowing thru vents and the outside air) of about 40 degrees. So if it's about 45-50 the system may not run because the system can't achieve an inside air temp of 10-20 degrees thru the vents.
Thanks for the input.
Old Mar 17, 2007 | 05:18 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: A/C ambient temp. switch
I`m pretty sure all compressors have a low ambient cut off. Wait until it gets warmer out and check the refrigerent charge in the system. In the summer mine blows cold as ice.
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
69Volunteer
Sep 30, 2015 10:39 AM
