mach1 vs cobra
RE: mach1 vs cobra
the 99, 01 cobra's lose to mach1's due to gearing and the crappy irs they came with, (as stated above) they have a bit more power but it doesnt make up for the wheel hop they will experience. the 03 + cobra's, even without the sc would give the mach1 a run for its money cause of the improved irs.
RE: mach1 vs cobra
+1 Mach1
The Mach1 has 03/04 Cobra heads which are some of the best flowing heads around, the exhaust side flows better than the FR500 at every lift level.
There is a large weight difference between the two just because of the IRS. The gear difference also helps greatly. The cams are still the same with .397" lift.
Things can also change as Ford has different exhaust cams from each side and timing can be far out as well. It depends on the factory tune and the driver, but almost always the Mach1 will win. Not to mention I think the car is just a lot more attractive
Now the downer.... The Mach1 has a block that is only good for about 600hp before the block itself starts to fail, the Cobra block is an aluminum design prior to the Mach1's and can handle 1200hp when prepped propperly.
-Eric-
-Eric-
RE: mach1 vs cobra
ORIGINAL: jmat2407
Let me shake things up a little bit. What if the mach is an auto. Who you going with then??
RE: mach1 vs cobra
01 Cobra vs. 03 Mach 1 Video (both have stock motors)
http://www.youtube.com/watch?v=65EFuV4n--w
