Porting headERS!
Old Nov 11, 2004 | 07:48 PM
Acer2428's Avatar
Acer2428
Site Mod
Default Porting headERS!
Yep:
Got my FRPP ceramic coated headers today (thanks, bud!) and they look sweet, except they could use some help at the intake ports where it meets up to the block...Can I grind this down or will it mess up the coating? Should I just polish it?
Thanks.
Old Nov 11, 2004 | 07:53 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Porting headERS!
headers don't have intake ports but I know what you mean
what are you talkin about, cleaning up some of the uglyness on the inside of the tubing from the welds? Unless its bad don't mess with it.
Oh, and make your sig alittle smaller please so it doesnt stretch out the forums everytime you post!
Old Nov 11, 2004 | 08:01 PM
Acer2428's Avatar
Acer2428
Site Mod
I didn't know what to call them????
Ok, it's welded on the inside and some metal has built up and sticks about 1/8" all the way around and looks like it would impede flow. Looks like if I could cut that down a lil I'd be golden....like port matching almost.
Old Nov 11, 2004 | 09:46 PM
Chopper's Avatar
Chopper
If you KNOW that the excess material that you remove will not effect the weld strength then use the gasket as a template and grind away.I would use great caution because if you remove too much then those new headers are going to fall apart.
Old Nov 11, 2004 | 09:54 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
I wouldnt mess with it... just the headers alone is going to mke the exhaust flow 50X better.
Old Nov 11, 2004 | 10:52 PM
Acer2428's Avatar
Acer2428
Site Mod
I suppose.... On one header tube... (2nd one from front on pass side header) it looks as though it's freaking JAWS. It had teeth! I will try to draw a picture...it looks weird as SHIZ!
Old Nov 12, 2004 | 01:30 AM
Dan04COBRA's Avatar
Dan04COBRA
Clean it up, use the gaskets as a guideline.
Last thing you want is turbulance you don't need.
Old Nov 12, 2004 | 01:38 AM
Redline03GT's Avatar
Redline03GT
Yeah just clean em through if you can, with a dirty toothbrush or something, but i wouldnt try to port them though. They will get the job done.
Old Nov 12, 2004 | 01:41 AM
Acer2428's Avatar
Acer2428
Site Mod
why the hell would I clean them with a toothbrush????? HAAHAHAHA
I'm going to file down the teeth I described and leave everything else alone!
Thanks!
Old Nov 12, 2004 | 01:54 AM
Redline03GT
Oh i thought you were just talking like some type of buildup... Yeah i guess just get rid of those like you said, and then leave the rest alone. I imagine it would work fine.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
TfcCDR
Sep 14, 2015 12:08 PM
