7.5" rear
RE: 7.5" rear
ORIGINAL: 97targa
Nothing!
ORIGINAL: weasel1088
what parts of the 7.5" are the same as the 8.8"????
so i guess i need to get an axle from a junkyard or something...
RE: 7.5" rear
the guys at the shop told me the axle shafts were the same...i thought at least the brakes were the same?? i know the housing itself is different since the 8.8 is obviously larger...
ORIGINAL: 97targa
Nothing!
RE: 7.5" rear
If you build the 7.5" right it will hold up against massive torque and will produce higher power levels to the wheels because its a lighter rotating gear and overall is lighter. Though the 8.8" has more out there for it when it comes to our mustangs but the SHO guys like the 7.5" a lot.
RE: 7.5" rear
ORIGINAL: NeoTokyo
does anyone know about the brakes and shafts?
RE: 7.5" rear
I would get a second opinion on what rear end you have in your car before you go through the heartache of switching it out. Because like already stated your car came with a 8.8 from Ford.
Check out this site it shows a pic of the difference between the 2. Yes it's a Cougar site but it's all the same for the most part. 7.5 and 8.8 Pics
