burnout time?
RE: burnout time?
Sorry but you're just not going to get the full potential out of a Nitto DR without a good 8-10 sec. burn. It took me about 50 passes to realize this. After giving them a good 8-10 sec. burn I was pulling low 1.80 60's. With a less burn I couldn't get out of the 1.9's. This was at 14# with a 275x40x17" , also back into the water to wet them then pull out of the water and burn them good in 2nd gear if you have 3.73's or lower.
Jay
Jay
RE: burnout time?
ORIGINAL: StangTangGT
i thought people say to avoid the water box? what does this effect?
If you drive THROUGH the water box, alot of times your front tires will get water on them which in turn can get on your rear tires when you don't want it to.
RE: burnout time?
ORIGINAL: mdvaldosta
oops yea, without gears though its hella hard to start a 2nd gear burnout.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
