Wheel spacers.
Wheel spacers.
Anyone using wheels spacers on there 18" wheels? preferably saleen replicas, what size are you using in the rear? I measured what it would be for the rim to be fluch with the fender and its 3/4" but they only make spacers 1/2" and than 1"
RE: Wheel spacers.
ORIGINAL: GolfmanSpeck
I know you asked about 18", but i thought i would tell you anyway. I have the 17" GT with 1" spacers in the rear.
My friends got 18" bullit replicas but there back spacing is +22mm and hes using a 1" spacer and it looks real good. But my saleens got a +28mm back spacing so it wont look the same. I dont want it to look dumb and stick further out past the fender.
RE: Wheel spacers.
I have 18x9 Replica Saleens, and I was recommended some 1" billet spacers.
So that is what I will eventually go with.
I don't think it will protrube that much. Also the sn95 is different, and there wheels tuck much further underneath the fender.
RE: Wheel spacers.
my spacers don't have their own studs on them. I have studs that are about an inch longer and the spacer just slides over them. Then the rims then the lug nuts.
ORIGINAL: Durr727
RE: Wheel spacers.
Now im thinking just buy some Moroso studs, which are 3" long. Stronger and have a longer unthreaded nose which helps prevent stripping. (broke one stud in the rear anyways, whoops) The stock studs are 2" long. So if I use a 1" or 3/4" spacer I probably will be ok using the regular lug nuts.
How difficult is it to replace the studs in the axles? Just use a hydrualic press to press them out and in? Does the ABS sensor just slip off, so it doesnt get in the way?
