Old Oct 20, 2015, 11:05 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
keyless entry remote programming instructions
Old Mar 23, 2007 | 12:08 AM
klfutrelle's Avatar
klfutrelle
Default keyless entry remote programming instructions
Can someone tell me how to program a keyless entry remote for a 2003 gt. Thanks for the help.
Old Mar 23, 2007 | 12:12 AM
CoolAid's Avatar
CoolAid
Default RE: keyless entry remote programming instructions
How to reprogram your remote entry
transmitters
You must have all remote entry transmitters
(maximum of four) available before beginning this
procedure.
To reprogram the
remote entry
transmitters:
1. Ensure the vehicle is
electronically unlocked.
2. Put the key in the
ignition.
3. Turn the key from the 2 (LOCK) position to 3
(OFF).
4. Cycle eight times rapidly (within 10 seconds)
between the 3 (OFF) position and 4 (ON). Note:
The eighth turn must end in the 4 (ON) position.
5. The doors will lock, then unlock, to confirm that
the programming mode has been activated.
6. Within 20 seconds press any button on the remote
entry transmitter. Note: If more than 20 seconds
have passed you will need to start the procedure
over again.
7. The doors will lock, then unlock, to confirm that
this remote entry transmitter has been programmed.
8. Repeat Step 6 to program each additional remote
entry transmitter.
9. Turn the ignition to the 3 (OFF) position after
you have finished programming all of the remote
entry transmitters. Note: After 20 seconds, you will
automatically exit the programming mode.
10. The doors will lock, then unlock, to confirm that
the programming mode has been exited.
Old Mar 23, 2007 | 12:16 AM
klfutrelle's Avatar
klfutrelle
Thanks, seems simple.
Old Mar 23, 2007 | 12:18 AM
01GTCONVERTABLE's Avatar
01GTCONVERTABLE
klfutrelle, where did you get your extra key fob?
Old Mar 23, 2007 | 12:23 AM
klfutrelle's Avatar
klfutrelle
Ebay.
Old Mar 23, 2007 | 12:26 AM
01GTCONVERTABLE
Make sure you let me know if it works, I've been a little gun-shy about getting it off there.
Old Mar 23, 2007 | 12:28 AM
lsustang04's Avatar
lsustang04
How much does it cost to get another key made?
Old Mar 23, 2007 | 12:48 AM
klfutrelle's Avatar
klfutrelle
$72 per key at the ford dealearship. Because of the computerized chip in the keyyou have to get two keys .
Old Mar 23, 2007 | 12:54 AM
lsustang04's Avatar
lsustang04
So even if you already have one you still have purchase two more for a grand total of 3 keys. I really just want one copy of the key I have now.
Old Mar 23, 2007 | 01:08 AM
klfutrelle's Avatar
klfutrelle
if you only have one key for your car you will have to get two keys made at the ford dealership or pay a locksmith $250.. the programming procedure requirestwo keys to program a key. so if you only have one you are screwed..
