Cleaning Engine?
Cleaning Engine?
What tips can you guys give me to clean the ol engine? Should I take it apart piece by piece and clean like that? Or is there something else I can do. Any specical tools?? Any tips at all??? Thanks in advance.
RE: Cleaning Engine?
Spray it with degreaser and hose it down. Then dry it all off and then spray it with CD-2 engine detailer. Make sure you cover up all the electrical **** before you apply water just to be safe.
ORIGINAL: PaintballFreak
What things should you cover up to keep water off?
Also, when you use the CD-2, try not to get it on the belt (according to the directions)
AHemm.... Strart your car...... get out of Car, Pressure Wash the car while its Running. dont cover anything up, Just Dont go heavy duty on Electrical stuff. (dont wash with car off). Then when thats done, get ArmorALl Detailers Spray(3-4dollars Autozone) and Spray the WHOLE Engine Bay(go easy on the Connections again you can spray them just not Much) Let the ArmorAll sit for a couple mins, Wash off with a Hose then it will look BRAND NEW!!!!
