timing chain replacement
Old Mar 24, 2007 | 04:19 AM
wildazme's Avatar
wildazme
Default timing chain replacement
when do you have to replace the timing chain on our cars? i have 98000 on mine as of now, just wondering.
Old Mar 24, 2007 | 04:23 AM
Chubstang's Avatar
Chubstang
Default RE: timing chain replacement
the timing chain is not a maintenance item on these cars, thats usally only with belts.
Old Mar 24, 2007 | 04:24 AM
lizzyfan's Avatar
lizzyfan
Underboss
When it breaks...it's not like a belt!
Old Mar 24, 2007 | 07:43 AM
97targa's Avatar
97targa
You have to worry about the tendioners and the slides mare so than the chains! I would say 100kmi and it's a good idea, but doesn't mean you can't get 150kmi outta them???
Old Mar 24, 2007 | 10:30 AM
wildazme's Avatar
wildazme
whats the going rate for a replacement of one?
Old Mar 24, 2007 | 11:13 AM
ackuric's Avatar
ackuric
I had a tensioner fail at 80,000 miles, caused the chain to slap my guides and cause a 'slap sound' replaced both tensioners (even though driver side failed) and the one guide, and all is well.
Old Mar 24, 2007 | 12:05 PM
wildazme's Avatar
wildazme
how much was it?
Old Mar 24, 2007 | 12:18 PM
AJ06GT's Avatar
AJ06GT
Not as much as the hassle of changing it probably. If you plan on doing a PI swap anytime, that's the perfect time to do the tensioners though. That's what I'm planning on doing.
Old Mar 24, 2007 | 12:27 PM
undecided.steve's Avatar
undecided.steve
ORIGINAL: AJ97GT
I would do the chains, tensioners and sprockets all at the same time that you are doing the heads.
See if Ford Racing has a beefed up kit or something.
Old Oct 28, 2008 | 05:16 PM
samtoyo's Avatar
samtoyo
Question HELP
yea i just replaced my tensioners but i have to ask befor i take the teniioners and guides off do i need to use one of those cam lock tools
