Fuel additives
Old Mar 27, 2007 | 08:50 AM
tool fan's Avatar
tool fan
Default Fuel additives
I run a fuel injector cleaner through my gas tank about every 1500 miles or so....... thoughts???
Old Mar 27, 2007 | 11:22 AM
jpmustanggt's Avatar
jpmustanggt
Default RE: Fuel additives
It's not a bad idea, can't hurt anything.
I do it every oil change.
Old Mar 27, 2007 | 11:45 AM
elite130's Avatar
elite130
I personally wouldn't waste my money on any additives. The fuel that you get out of the pumps already has fuel additives that prevent carbon buildup, prevents clogging fuel injectors, and overall keeps your fuel system clean. There are some gas companies that use more additives than others, but overall, the gas that you put in your car, regardless where you get your gas, has all the additives to keep your fuel system clean. My dad has worked at an oil refinery for over 35 years making the fuel that we all put in our cars. He and his coworkers say the additives that you can get on the shelves is a waste of money. That's just my $0.02.
Old Mar 27, 2007 | 11:57 AM
lizzyfan's Avatar
lizzyfan
Underboss
ORIGINAL: tool fan
Why?
Old Mar 27, 2007 | 12:21 PM
03mustgt's Avatar
03mustgt
ORIGINAL: lizzyfan
ORIGINAL: tool fan
Why?
+1, sounds a bit overkill to me.
96GT226410's Avatar
96GT226410
CSMG Moderator
I'm not really a fan of these. Save the money and just buy new injectors.
Old Mar 27, 2007 | 12:32 PM
Adam03GT's Avatar
Adam03GT
ORIGINAL: elite130
+1 .. They are a waste
Old Mar 27, 2007 | 01:04 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
the only time id run fuel injector cleaner (besides seafoam) is if the car is running rough.. i start rulling out the cheapest problems before anything else. i wouldnt say the oil companies add alot of those additives i head chevron adds the equivelent of 2-5 bottles of fuel injector cleaner per 1000 gallons. But i would still save my money. Every oil change is a bit overkill
Old Mar 27, 2007 | 01:10 PM
Adam03GT's Avatar
Adam03GT
Well of course it depends on where you buy gas from... Their is top teir rated gas ...which is what you should be using... And then there is the others which is just the bottom of the barrel crap...
My whole family used this little no name gas station because it was right by my house and all in the same month my car, my dads car, and my moms all threw a code! Took them all to autozone and they told us it was a gas related problem..... So i only use the top teir rated gas which does in fact have plenty of additives.
Old Mar 27, 2007 | 01:14 PM
06mustang88's Avatar
06mustang88
ORIGINAL: elite130
so what gas companies are the best to go to in your dad's eye? i always use sunoco because it seems to make my car run best. sheetz gas sucks!
