leak
I waswondering if someone can tell me, that have or had the same problem as I do. When is rainning outside (most likely heavy rain) the water is getting inside my car , right were the seatbelt is monted on both sides. I had replaced the door gaskets but still leaking (It's driving me nuts.) I will be thankfull fore some advice. Thanks
Did you use the stock style weatherstripping? When did you replace them? Did you try seeing if the TOP of the window seal was compromised? It might not be leaking in right at the side the water is, it might be dripping down.
bradleyb
Nov 27, 2015 07:50 PM
