Diff. Fluid capacity
Old Mar 30, 2007 | 10:21 AM
xcodegt's Avatar
xcodegt
Default Diff. Fluid capacity
How much does it need, what weight to use, and does royal purple Maxgear already have the additive in it?
Old Mar 30, 2007 | 10:26 AM
redgt2000's Avatar
redgt2000
Default RE: Diff. Fluid capacity
um when i change mine, i was taught at the lube to drain from the bottom 'drain" hole, plug it then fill the "fill hole"with fluid until it pours out of the fill hole and levels off, stick your pinky in to make sure the fluid it at the top then plugit up, start your car and just run through the gears, that is for the manuel tranny new edge mustangs.the automaticsi dont know about
Old Mar 30, 2007 | 11:00 AM
xcodegt's Avatar
xcodegt
I am not talking about the transmission. i am talking about the rear end. It has an 8.8, a manual or automatic transmission is completely and utterly irrelevant.
Old Mar 30, 2007 | 11:52 AM
ponysnake99's Avatar
ponysnake99
2 quarts and 2 bottles of friction modifier should fill it up, if not you'll need some of a third quart
Old Mar 30, 2007 | 12:03 PM
xcodegt's Avatar
xcodegt
just wondering how much I should buy
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
wraith777
Sep 28, 2015 10:49 AM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
Sep 25, 2015 06:42 PM
