PROJECT 700!! (PICS!!)
well... i had to think of a name... its project 700. lol.... everyone else had a project name but me so i wasnt as special. lol... but anyways... here is an update with up to date pics of the motor as it sits now... what do you think?? its nearing completion
stage 3 ported heads with oversized stainless steel valves...
not much left!!!
And the new shortblock before i tore everything apart...
Notched 18cc Manley Forged Pistons
not much left!!!
ORIGINAL: Shawn02GT
you were running a P1SC before correct? what blower are you going with now and how much was all the engine work?
looks great [8D]
looks great [8D]
the engine work has been kinda pricey... so far i have probably over 6k invested just in the build...
heads: 1k
shortblock and accessories: 4k
gaskets and some other stuff: 700
cams: 500
valve springs: 225....
just a bunch of stuff that adds up... i still have to buy some 60lb injectors and get some dual cobra pumps or something.
Are you gonna swap out the SQ for a T or something? Not to put a damper on anything here, but with the SQ, even with a new 8 rib setup, I think your gonna be shredding belts and maybe even max out the blower.
T trim FTW.
T trim FTW.
ORIGINAL: 2000GT4.6
T trim FTW.
T trim FTW.
From what I have heard the SQ likes to rip up belts almost no matter what if you exceed about 550-600. 600+ on a SQ... its gonna be difficult but you might get there with the ported heads etc... its been done before. 700 WHP though....
Gonna be stout either way. Plus, you can always sell the SQ later and buy a T trim for more boost. The T should get the same job done with a less agressive pulley and not rip up the belts as much, just make sure you keep a set of vice grips and a pump pliers in the car along with an extra belt (stupid vortech bracket covering up the tensioner socket slot FTL!)
ORIGINAL: 2000GT4.6
ORIGINAL: Shawn02GT
so when are you dropping the engine into the bay [&:]
i say within a month and she will be running again... in 2 weeks i will have another pay check and also my tax money so it should be good to go then..
How far are you from MPH in atlanta. I am gonna drive 12+ hours there for a tune when my SB goes in.. imo they are simply the best. LOTS of 600+ whp 2vs coming out of there.
On the tensioner, what I do is clamp a GOOD (not cheap) set of vice grips on one of the ribs on the tensioner. Then, I take a set of adjustable jaw pliers, put em on the vice grip, and use that to turn it. Goes on/comes off easy with the right tool.
Get yourself a gatorback belt when you do it, supposed to be the best. I have not had any belt issues but I think I am gonna upgrade soon just for peice of mind (stil on the stock vortech belt).
Fuel wise, I thought the dual pumps/cobra setup was a direct drop in? If that doesn't get it done, get a BAP for the dual tank setup and you should have no problems.
I dunno about the 60 pounders... I think they are about the same price everywhere. MPH has them on their website.
