Pinging on hard acceleration??
#31
RE: Pinging on hard acceleration??
Just got finished taking the intake off and looking down the intake and there was a crap load of carbon on the valves. We soaked them with solvent, put it back together, cleaned the injectors with 70 psi injector cleaner and now it runs like an *** raped ape. The ping is gone and it idles so much better. The fuel pump is on it's last leg, I noticed the other day it had a long start a couple of times and now it is sceaming for mercy a little more than before.
#32
So theoretically, it could have been all of the variables, or just one... It's good that at least the pinging is gone, however, you may want to do a compression test, just to make sure things are still kosher, and that you're not just feeling the difference of timing not being pulled as a result of the pinging, or if things are tip-top..
JT
JT
#33
I don't think I will need to do that due to how good it runs at this point. I do know the next thing that I need to do is replace the fuel pump. I put a fuel pressure gauge back on last night and had good idle pressure then when I turned off the engine it leaked down to 0 psi. KOEO and it pumped back up and leaked back down but it is very intermittent. Fords are so known for the fuel pumps leaking down and going tit's up.[/align]Now it's a matter of a Ford pump or aftermarket performance pump. I have no plans of supercharging the car but I will be doing PI heads at some point in the near future. [/align]
Matt's 95 Stang
10-05-2015 07:16 AM
