cams
just the cams themselfs?? i could have it done in around an hour...
but when you get to valvesprings... expect to start at 8 am... and stop at 10pm.. then start 8 am the next day.. and you may be done by the end of the day... thats if you got good enough at getting those springs off
pull valve covers off. They make a specific tool that holds the timingchains. Takes about 3 hours for skilled people I would say all day for you, but you only need to remove the valve covers. The stock springs should be fine if you stay with comp 270ah's PTV clearance shouldn't be any issues as long as you keep chains lined up perfectly! Don't get adj. gears, they are for people with experience and those without programmers!
junior04
Sep 28, 2015 10:53 AM
