squeeky over bumps
squeeky over bumps
After i got my eibach pro kit installed seems like my back left side is real squeeky when i go over bumps and stuff. Could putting the spring in wrong or something cause this..??
RE: squeeky over bumps
i had the squeek to, and im not lowerd, what i came to find was the tiny shocks on the rear end that help dampin noises and that dry out and squeek, may not be the case for you, but you can check, thats what squeaked in my rear end over bumps, just thought i would throw that out there
Also, since you lowered it, the Control arm bushings are seeing different forces applied to them.. IIRC, the rear springs are flat, and rest on the flat lower perch on the LCA.. Isolators could be a solution, but my bet is either struts or bushing hardware...
JT
JT
