HELPPPPPPPPPPPPPPPPPPPPP!
I have a 98 mustang gt and when i am at a red light and it turns green i have a huge problem. When i release the clutch and press the gas it dosent start to go after a while, kinda of jerks a bit. It rides and shifts fine after it starts going. IS THIS A CLUCTH PROBLEM OR A TRANSMISSION PROBLEM? THANKS GUYS
*I HEAR A WEIRD SOUND COMING FROM THE TRANNY, LIKE A WHINNING SOUND!*
ORIGINAL: xander0561
I'd check the fluid, see if it has metal in it, that will let you know if its a trans problem.
ORIGINAL: 97targa
He has a 5spd not an auto..lol Yeah sounds like your clutch is bad! A whining noise is usually from a bad throwout bearing, but the slip is from the pressure plate! Has nothing to do with your fluids
just tryin to help.and+1
if your going through all the trouble for the new bearing just replace the whole thing.
http://www.latemodelrestoration.com/...1&comp=LRS
check it out
WHAT CAN MAKE THE CLUTCH GO OUT? I DONT RACE, IM NOT HARD ON THE CLUTCH OR GAS AND I TREAT MY CAR LIKE A BABY! PREVIOUS OWNER MAYBE? IVE ONLY PUT 1500 MILES ON IT SINCE I BOUGHT IT!
I FOUND THIS ON EBAY IS THIS A GOOD CLUTCH KIT?
http://cgi.ebay.com/ebaymotors/F1-RA...mZ150108359142
Is it screeching? I had an issue with my clutch a while back - it was screeching... it ended up being a Throwout bearing, which in turn makes you need a new: clutch and flywheel normally. Good luck man.
ORIGINAL: darthvader
