REV QUESTION?
RE: REV QUESTION?
Clean / adjust your IAC is one thing you can look into. It's hooked up to your throttle body - look it up online. Just DONT spray anything in there to clean it, factory coats the inside of it to keep it clean from what i've read / heard.
RE: REV QUESTION?
https://mustangforums.com/m_2625353/tm.htm
Still waiting for them to add it to the how-tos. Also in there i listed 99-04, it can be done with 96-04
RE: REV QUESTION?
I put a nut/washer(attached) i had lying around that had a 3/16" hole (basically allow a small pinhole instead of the full tube), in the large IAC hose. Shoot for a 3/16 hole at first and go bigger if it isnt right. 3/16 worked for me, no problems.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
