What octane and why?
Old 04-10-2007, 01:32 AM
01GTCONVERTABLE
01GTCONVERTABLE's Avatar
Default What octane and why?
Since I bought my 01 GT, I've been running 93 octane in it. I've heard it burns better and cleaner. I've also figured it costs me and additional $4 per tank, which isn't that big of a deal to me. There is also racing fuel...100 octane, is there any point to that? At $4+ a gallon I can't see why, but I don't know. I also see all these "Fuel System Cleaner" and "Injector Cleaner" and "Octane Boost"....do those acually do anything or is it just to sell some useless products to people like me who don't know better?? Any answers would be helpful. At least I could give a good reason if someone asked me why I put in Super instead of Regular. Thanks in advance!
01GTCONVERTABLE is offline
Old 04-10-2007, 01:37 AM
gt96stang
gt96stang's Avatar
Default RE: What octane and why?
if you're not
FI, high compression, adavanced timing....
you don't need anything other than 87 in your stang... you're just wasting your money
gt96stang is offline
Old 04-10-2007, 01:38 AM
POISND U
POISND U's Avatar
Octane is a unit used to measure the fuels resistance to detonation. Unless your engine knocks, you're just wasting your $ and burning up your cats.
Exactamundo, homie...
POISND U is offline
Old 04-10-2007, 01:43 AM
04MustangGT
04MustangGT's Avatar
You shouldn't use anything but 87 octane. From what I've heard alls you are doing to your car is wasting fuel that isn't being burnt up. If you modded and tuned your your motor than higher octane would be better.
Right now all that is happening is your fuel is getting spark and only a limited amount ofit is actually burning and the rest is being deposited on the top of your piston.
If I am wrong, please someone else correct me. And help this person out. Don't want to see his Mustang pinging.
04MustangGT is offline
Old 04-10-2007, 01:47 AM
mikemic
mikemic's Avatar
The GT is designed to run on 87 octane, so as mentioned above, you're likely wasting 10 to 20 cents per gallon for everyday driving. As far as cleaners, I just try to use gas from a station with modern tanks and pumps that sells a lot of gas so I get clean gas. That's probably more important than brand name.If you do think you need a fuel system cleaner, Chevron Techron concentrate is considered by many to be one of the better over the counter products.
mikemic is offline
Old 04-10-2007, 01:52 AM
sprostang
I ♥ Acer
sprostang's Avatar
BG 44K fuel system is the best you can buy. It`s $20 per can and it`s well worth it. It does work.
sprostang is offline
Old 04-10-2007, 01:54 AM
04MustangGT
ORIGINAL: mikemic
Don't go to one of those No-Frill (Can't find a better word for them) gas stations. There is usually water in their gas.
cahtr6
cahtr6's Avatar
If you want to run the higher octanes get that timing advanced either by the steeda adjuster or a handheld tuner than you will see the benefits of higher octane fuels and your gas mileage will also improve.
cahtr6 is offline
Old 04-10-2007, 02:01 AM
04MustangGT
ORIGINAL: cahtr6
Is that how you advance the timing nowadays?
Remember the days when you used a timing light, chalked your damper, the timing plate, and turned your distributor to 5 more or less degrees?
"Pepperidge Farm Remembers!!"
Old 04-10-2007, 02:10 AM
cahtr6
cahtr6's Avatar
We lost our distributors now we have to talk to our computers
cahtr6 is offline
Quick Reply: What octane and why?
