Comp or VT Cams?
RE: Comp or VT Cams?
ORIGINAL: cammed99gt
No the stage 2 comp are only .550 lift i thought.Idont think uhave to doanything to make your comps. to fit.If your going for sound then vt all the way but on horsepower i wouldnt thinkthere much of a diff. in horsepower
didnt know that about the comp. but i never messed with themeither.thanks for the info though.I would go vt over comp. any day.just have heard to many good things about vt cams.Im going that rout when i rebuild my motor
those sound awesome do you know the part number for those cams?
I got stage 2 in mine and no problems here.Here's one of my sounds clip
http://videos.streetfire.net/video/0...f70106d321.htm" target="_blank">Click to see
im running the same year car as you and the stage 2 cams from VT work AWESOME.. the only thing you have to do is upgrade your springs and get a tune ASAP. the car will not run right until it gets tuned. stage 2 vt cams were NOT easy to put in, but they didnt require anything to be cut. however, what cam is easy to put in.
