need help on midpipe install
Old Apr 14, 2007 | 11:55 PM
97modifiedmustangGT's Avatar
97modifiedmustangGT
Default RE: need help on midpipe install
I did the same as KEENO. Just use you old ones, they should work.
Old Apr 15, 2007 | 04:55 AM
Donnie's GTS's Avatar
Donnie's GTS
studs for the SLP x HAD to be removed, it would not snug down otherwise, anyways it is complete, but with a slight leak, so Im gonna retighten and what not, and if that doesnt do it, then when i get the tips welded on I'll have them fix that too.
Old Apr 15, 2007 | 06:51 AM
lizzyfan's Avatar
lizzyfan
Underboss
Just installed an o/r H pipe and the metal gasket on pass. side between header and o/rpipe seems to be a one time use gasket. I have a leak as it would not seal on the new setup and it's OEM so ordered from Ford. The hissing/ticking is drivin' me nuts![:@]
Old Apr 15, 2007 | 06:53 AM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: BullittJim
Your going to have your tips welded onto the catback???
Old Apr 15, 2007 | 02:10 PM
Donnie's GTS
ORIGINAL: 2000GT4.6
Yes, there are set screw that go on the hangers that will not hold the exhaust tips in place, and the tips keep moving inward and not staying centered.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
