What kind of oil?
What kind of oil?
Im going to change my own oil for the first time in my mustang this weekend.Is there some betterkind of oil I should use? What kind of oil do you guys use? What about the filter?
RE: What kind of oil?
You have opened Pandora's Box with this question! Some guys use Mobil 1, Ams, Castrol Syntec or Royal Purple. I would tell you to use one of the above oils and you will be fine. Just make sure it's a full synthetic with a decent oil filter. FYI, if you use one of the above, don't change your oil every 3k miles. You will be throwing money away.
ORIGINAL: E714FEVER
Mobil 1 5w20 with a motor craft filter.In you owner's manual it should say use 5w20 and i would only use what is recommended
My point is, you don't have to use the recommended oil. I always use 10W30 because I tend to be hard on cars and it's a little added protection. They recommend 5W30 or 20 whatever, to get the lower emissions rating. If you don't have a clue, then use whats recommended. If you're comfortable with something else, then use that.
