Installing catback help
Old Apr 18, 2007 | 06:49 PM
  #21
HamMach1's Avatar
HamMach1
Default RE: Installing catback help
Wow i just learned how ****ty the jack that comes with it is...im going to autozone to buy a better one.
Old Apr 18, 2007 | 06:55 PM
  #22
OzzDOA's Avatar
OzzDOA
Yeah, you should have at least a 2 ton floor jack. Don't use the piece of crap they give you for changing tires.
Old Apr 18, 2007 | 08:06 PM
  #23
HamMach1's Avatar
HamMach1
Yeah I just got a2 ton jack made by duralast
Old Apr 18, 2007 | 08:32 PM
  #24
HamMach1's Avatar
HamMach1
Cna someone take a picture of where I need to place the jack to lift the car?
Old Apr 18, 2007 | 08:36 PM
  #25
blueherd02gt's Avatar
blueherd02gt
I have that one, the fukking welds broke and damn near killed me while putting my H-pipe on my s197. Luckily I had some 4x8" under the tires (almost an inch lower than the jacks), **** duralast
ORIGINAL: Slicktastyk Matt
Old Apr 18, 2007 | 08:41 PM
  #26
clarehills's Avatar
clarehills
Here you go.
[IMG]local://upfiles/60884/BD78CFC160FE4D1DB478157DF738343B.jpg[/IMG]
Old Apr 18, 2007 | 09:30 PM
  #27
undecided.steve's Avatar
undecided.steve
ORIGINAL: redass02gt
good lord, you cut that **** off with a dremel?!?!? with th elittle 2 inch diameter cutting tool??!/ hilarious cause it wasn't me. [sm=icon_rofl.gif]
Sure...
Took about 15 minutes per side and a hell of a lot easier than using a hacksaw.
You need to use a heavy duty cutting wheel though.
Never underestimate the power of the Dremel tool.
Most people don't use it properly and thus have problems.
High RPM and let the wheel do all the work and it cut though like butter.
Old Apr 18, 2007 | 09:36 PM
  #28
undecided.steve
Well, yall really didnt answer the question but the other advice really helped. What I was hoping to get an answer for was do i put the jack stands up in the rear and put and like wheel blockers or a piece of wood or whatever in the front of the front tires or what?
I backed mine up on the ramps and installed it that way.
Put a floor jack with a 2x6 on top (the long way) to jack up the body a little bit so the you can get the pipes over the rear axle.
Truly the most difficult part is getting the hangers into the rubber mounts.
What a PITA even using dishwashing liquid to lubricate.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
