ok, cork or rubber
ok, cork or rubber
ok put a short throw in my car 1-2 weeks ago. Shifter didnt come with a gasket, so i used some RTV. it started whinning so i decided to check her out (fluid level) when i did.. very low. SO i toped it off and re applied some RTV. now 45 miles later back to whining as where when i toped it off it stoped. Should i just make a gasket with cork or rubber? and if so which is best?
RE: ok, cork or rubber
I think you have a different problem. Crawl under the car and see where the fluid is leaking from it should be obvious. How are you checking your fluid and noticing that it is low?
ORIGINAL: sunguf
you might be leaking somewhere else or not puting enough RTV, RTV should be fine the fluid shouldn't be able to come up there and out
