cobra compression
RE: cobra compression
you can raise compressoin ratio also by decking the block or milling the heads, or even using a thinner head gasket, and don't be getting smart newb
ORIGINAL: Wings65288
what exactly does the compression ratio mean, like you said for a cobra it's 8.5:1. and also you can raise it to 15-20 psi with the stock eaton blower? or would you have to get a kenne bell to do something like that? or would the diablo chip with the eaton work fine?
Lets help a brother out...
11-10-2015 11:39 AM
