cobra compression
Old Dec 2, 2004 | 01:36 AM
formula87350's Avatar
formula87350
Default cobra compression
What is the compression ratio for the 03-04 Cobras? I was just wondering how the hell those things take 20+ psi. Is that on stock internals?
Old Dec 2, 2004 | 01:39 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: cobra compression
The stock internals are forged on the '03/'04. With a good tune 15-20 psi isnt that big of a deal to them.
Old Dec 2, 2004 | 02:37 AM
94Cbra's Avatar
94Cbra
I think the compression ratio is 8 somthing. Like JD said, those bishes are forged all out. 12 PSI is just getting started with onea those.
Old Dec 2, 2004 | 02:43 AM
StangTangGT's Avatar
StangTangGT
hey 94cbra you should upgrade to the stock 98 cobra style hood, with those snouts i think they are the best looking hood out there on that body style. one was ridin behind me today and it looked mean as sh*t!
Old Dec 2, 2004 | 12:16 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Whoops... sorry dude. The compression ratio for a '03/'04 Cobra is 8.5 to 1 .
Old Dec 2, 2004 | 01:18 PM
Wings65288's Avatar
Wings65288
what exactly does the compression ratio mean, like you said for a cobra it's 8.5:1. and also you can raise it to 15-20 psi with the stock eaton blower? or would you have to get a kenne bell to do something like that? or would the diablo chip with the eaton work fine?
Old Dec 3, 2004 | 02:29 AM
Wings65288's Avatar
Wings65288
anyone?
Old Dec 3, 2004 | 03:00 AM
00GT00's Avatar
00GT00
ORIGINAL: Wings65288
Lets help a brother out...
READ THIS
Old Dec 3, 2004 | 05:31 AM
tdogg31's Avatar
tdogg31
to my knowledge, i'm not to exact on this, compression ratios are figures based on piston configuration, air and fuel combustion ratios. the flatter the piston head the more pressure it will combust at the top of it's travel. domed piston create less compression because they have reliefs built in. the 03-04 cobras probably have domed pistons the lower compression (pressure) in the cylinders, thus not igniting the air/fuel mixture as strongly as a high compression engine. eaton blowers do not have enough volumetric efficiency to produce over 14 psi, so anything over the they are just creating heat not boost=detonation plus not horsepower gains. i hope this gives you a rough idea of your question
Old Dec 3, 2004 | 05:33 AM
tdogg31's Avatar
tdogg31
oh and you cannot raise compression ratio unless you change pistons. you can raise boost though
