Question about jacking car up
RE: Question about jacking car up
ORIGINAL: cliffyk
Here's Ford's recommended jacking points, they specifically state that the rear should not be lifted by a signle jack under the differential pumpkin...
i work at discount tire and have jacked probably 1500 ford vehicles from the diff so far....
ORIGINAL: djb1187
safety as the car falling on you or driving away? My buddy jacked mine up by the rear end pumpkin today to look at something underneath it and it started to roll a lil bit. so i had to put a brick on the front tire
It'll save you a trip to the ER or worse, the morgue.....
ORIGINAL: djb1187
ORIGINAL: SVTBill
i still dont know why...its like that on the F series too
ORIGINAL: cliffyk
ORIGINAL: dsg04gt
I heard that the reason for this is that there is a negative camber built into the rear axle or something of that sort. They say that jacking it up from the pumpkin can mess with that, but I don't really follow that to well :s.
ORIGINAL: SVTBill
ORIGINAL: cliffyk
if it had negative camber then how would all the rotating assemblies inside the axels spin?
ORIGINAL: SVTBill
ORIGINAL: cliffyk
Easiest way to remove tailpipes is with the car on jack stands, pop the tire(s) off. Put the jack under the shock mount and remove the shock bolt leaving the jack to support that side of the axle. Then just lower the jack until that sides pipe has enough clearance to remove the tailpipe. Beats the hell out of cutting the pipes. [:'(]
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
