k/n filter
Old Apr 23, 2007 | 10:28 PM
BigRed03GT's Avatar
BigRed03GT
Default k/n filter
hey guys, this may kinda be a stupid question, but anybody know how i can install my k/n air filter?, want to replace the old stock paper filter.
Old Apr 23, 2007 | 10:29 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: k/n filter
take out the old one and put in the new one.
Old Apr 23, 2007 | 10:35 PM
jthomsen85's Avatar
jthomsen85
Unbolt the little nut holding thefiltercover to the fender. After that pull the little clamp open thats around the filter cover. Pull the whole thing out and pop the filter in. Also while your doing that you should remove your air silencer. It is a piece of rubber sticking out of the filter shroud. they say it adds a couple hp.
99GTvert's Avatar
99GTvert
is my username.
It is a very simple process. Go look under your hood and locate the air box. You will see that clamp thing that holds it in place, you will also need to remove that nut/bolt/screw that holds it into place. Once you do that, then slide out the airbox and replace the filter. Very simple task.
Yes, I also recommend removing the silencer (the rubber thing that goes into the fender).
Old Apr 23, 2007 | 10:42 PM
BigRed03GT's Avatar
BigRed03GT
what does removing the air silencer do?
Old Apr 23, 2007 | 10:46 PM
kontroldkhaos's Avatar
kontroldkhaos
allows more air in forperformance,,it helps a little
Jskeezy84's Avatar
Jskeezy84
nothing! ^^^^
Old Apr 23, 2007 | 10:47 PM
davidsv8mustang's Avatar
davidsv8mustang
Here are some helpful links, different car year, but same process, u get the idea
http://www.mustangworld.com/ourpics/fcar/intke.htm
http://www.mustangworld.com/ourpics/fcar/knln1.htm
Old Apr 23, 2007 | 10:48 PM
BigRed03GT's Avatar
BigRed03GT
when it's removed, can it trigger a check engine light?
jthomsen85's Avatar
jthomsen85
It's function is to make incoming air quieter. But they say it is a restriction in the intake, They did an article in 5.0 magazine where they removed it and picked up like 2 or 3 hp.
