Ive been hearin a lot about blown spark plugs...
And its got me a little uneasy about doin my own. What steps should I take to ensure that it doesnt happen? Im assuming the plugs blow because they arent tightened down enough, or the coil pack is loose?
RE: Ive been hearin a lot about blown spark plugs...
Actually it can be caused by changing plugs on a hot motor. Threads galled due to overtorquing and no anti-seize. High cylinder pressures due to various reasons ie. boost/detonation. Lastly there is only about 4 threads that hold that plug in. Aluminum isn't forgiving at all and if you just he man the plugs in you are waiting for problems.
Use a torque wrench.
Change plugs ONLY on a cold engine
Use anti-seize
COP's have nothing to due with plugs blowing out
Use anti-seize
Well, the first one i did, engine was cold (hadnt driven the car in a day). didnt use a torque wrench tho, i just tightened it normally, didnt overtighten it. No antiseize tho, i was told it wasnt necessary.[&:]
Did thata week ago, took the car to the track this past saturday and ran it pretty hard, so far so good?
ORIGINAL: GreyStang
How tight do you guys tighten the plug? I've done the "tighten down by hand, then 1/4 turn tighter with a wrench" Is that about right?
Just take your time and dont force the plug in. If its not going in, dont make it. Buy a swivel for the back two plugs so you can get the right angle on it so it doesnt strip. Its not too bad, just dont rush it. I didnt do the tighten by hand then 1/4 as I dont see how in the hell you could get your hand to the back plugs to tighten them. I simply torqued it down with a ratchet. Im sure theres a certain ft/lbs thats supposed to be used, but I didnt have a torque wrench at the time.
Yeah, i had two of my mechanic friends come with me to autozone, and they pointed out everything id need (swivel, extender, socket), no torque wrench, nor antiseize.
