Pulls Right
ORIGINAL: MCanavan6
Stang pulls to the right all the time. I need to turn the steering wheel in order to keep it in line going straight but as soon as I let it go it pulls to the right and if I dont quickly grab the wheel and pull it left it will run off the road. Any ideas what could be the problem?
2. Swap left and right front tires. A shifted belt inside a tire can cause the car to pull. See if the car pulls the other way now.
3. Did it come on suddenly, like after you hit a hole or something? If so, look for bent parts etc.
4. Could also be a dragging brake caliper. Any smells coming from one side after driving?
5. Get the car aligned.
ORIGINAL: 1hotdrp
mine only does that on some roads and i think it needs an alignment.
But to Thread Starter Go to a Shop, Most of them Give u a FREE Alignment Check.
if its only on Some Roads the Roads may Be Slanted for Water to Run Off....
