Squeaking while riding down the road
Old Apr 26, 2007 | 05:09 PM
djb1187's Avatar
djb1187
Default Squeaking while riding down the road
I noticed that while driving down the road I can kinda hear a squeaking sound. Doesnt necesairly matter if I hit a bump or not and its not the TOB because i just had that replaced and no matter if clutch is in or out it does that. Any clue on what it can be?
Old Apr 26, 2007 | 05:30 PM
Fizzics Boy's Avatar
Fizzics Boy
Default RE: Squeaking while riding down the road
My car was squeaking hte other day too, but it was my exhaust. I had just swapped out the off road legs for cats on mine so i can get it inspected. I kinda half assed it since im putting the offroad legs back on. But check your exhuast and all the connections to make sure its all tight and stuff. Just a thought
Old Apr 26, 2007 | 07:31 PM
rmtaylor78's Avatar
rmtaylor78
check the TSB section...there have been bulletins about this in the past, seems like lots of people have a similar problem...
Old Apr 26, 2007 | 08:54 PM
ColinGT's Avatar
ColinGT
my also sqeaks but only when i hit bumps....
Old Apr 26, 2007 | 09:01 PM
lizzyfan's Avatar
lizzyfan
Underboss
Alot of times this can be attributed to the e-brake bracket on the driver side
Old Apr 26, 2007 | 09:07 PM
Sniper6677's Avatar
Sniper6677
Check for worn suspension components as well....determine if its comgin from the front or rear....another help if it could possibly be a suspension noise....try finding a background that has a dirt shoulder...and SLOWLY take one side off into the dirt and see if it sqeaks...then do the same for the other side. that might help you out if it is suspension related
Old Apr 27, 2007 | 12:57 AM
GodAmGT00's Avatar
GodAmGT00
There are a lot of things that can cause a squeak.. Worn CA bushings, sticky brakes, broken springs, blown struts/shocks, loose body panels...
Do you know if it's coming from the front or the rear??
JT
Old Apr 27, 2007 | 08:18 PM
djb1187's Avatar
djb1187
i cant really tell if its coming from the front of rear. All I know is that its annoying, im going to try and tell if its the brakes or what? how can i tell if the suspension is worn?
Old Apr 27, 2007 | 11:22 PM
BigTurbo6's Avatar
BigTurbo6
My car squeeks like that sometimes...and the ebrake was acting weird for a while...i need to check the bracket!
Old Apr 28, 2007 | 12:22 AM
djb1187's Avatar
djb1187
its coming from the outside of the car. its really audible when im riding next to someone
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
1Bad71
Sep 30, 2015 07:37 PM
mungodrums
Sep 28, 2015 10:54 PM
