Grille Delete Install Help!
Old Apr 27, 2007 | 02:59 PM
Car_Ramrod's Avatar
Car_Ramrod
Default Grille Delete Install Help!
so i tried to install my grille delete (3 piece) today...and failed horribly the first time around. the inner 2 screws on top of the stock grille are stripped and ive tried and failed to get em out. any ideas on how to get these freaking things out? i had to walk away from it cuz i was getting to the point where i wanted to throw the screwdriver lol. id like to get it done today, so any help would be appreciated.
Old Apr 27, 2007 | 03:11 PM
Red 5's Avatar
Red 5
Default RE: Grille Delete Install Help!
Are you talking about those lame *** plastic screws? If so, just pry them buggers out with a pocket knife.
Old Apr 27, 2007 | 03:13 PM
2000GT4.6's Avatar
2000GT4.6
I'm gonna go look on the car in a min (have to go put the mufflers back on lol) but are you talking about the pop rivit/screw things?
The entire thing will come out, but you need to get the center up and then it will come out with light force.
dubarado's Avatar
dubarado
ORIGINAL: Red 5
+1
try pliars... they give you new ones... wait til you get to the bottom of the grille... you have to peel it back to get to 4 bolts underneath... get neosporin for your busted knuckles.
Old Apr 27, 2007 | 03:39 PM
Car_Ramrod's Avatar
Car_Ramrod
id rather not break the screws...i bought the kit used and i dont believe i got the new screws with it.
...maybe the used kit wasnt worth the savings of like $40...
Edit: and yea...i was talking about the pop plastic screws. the two innermost ones that are held in by plastic mollys or whatever.
Old Apr 27, 2007 | 03:41 PM
DTK's Avatar
DTK
I had the same problem with mine.
I got em off eventually.
You can buy replacements at NAPA though.
2000GT4.6's Avatar
2000GT4.6
Take a pic, but they should come out and be able to be put back in. Hell, put a pliars on it if you have to, or heat up a screwdriver with a MAP gas torch and melt yourself a new slot if you stripped it so bad. Just be careful not to touch the paint
Old Apr 27, 2007 | 03:48 PM
laserred38's Avatar
laserred38
just go slow. and find the lightest screwdriver you have so you don't push the plastic screw back in with the weight of the screwdriver.
Old Apr 27, 2007 | 03:59 PM
Car_Ramrod's Avatar
Car_Ramrod
i was using such a small screwdriver i seriously could not use a smaller one.
and i dont have a gas torch...my tool selection is minimal. im in an apartment complex and dont have much room/time/tools to work on my car. im just trying to make do the best i can.
i think its about time to go try and screw with it again, no pun intended.
mtgldr
Feb 3, 2024 09:00 PM
2007CalSpec
Dec 13, 2020 11:42 AM
Roush05
Sep 10, 2015 12:23 PM
