Parked the car, and it started hissing!
I parked my GT in the garage, after a hot OC day of driving a little harder than usual cuz I got the accel. pedal mod done , and my car started hissing at me!!!
It was like every 2 seconds, it would hiss, and I was like WTF!!! I looked under the hood, nothing, looked under the car, and I foud what it was. My AC condensor is leaking water, like by the teaspoon, and it was dripping my X-pipe where it meets the headers, instantly evaporating the water.
Is a leaky AC bad? I've seen it on older cars, and usually it meant I had to change the freon...Is that my problem, or is it just normal. This is my first car, so bare with me here!
RE: Parked the car, and it started hissing!
Totally normal. If you had the a/c on it was condensation dripping onto the exhaust manifold. Next time slam your door and it will hiss alot louder. If it`s ever leaking refrigerant you`ll never see it leak out.
ORIGINAL: sprostang
ok all it is, is condensation from your air conditioning...its fine...just water moisture built up on the outside of it from being so cold...also if you were leaking refrigerant..it wouldnt puddle..its more of a gas...it would rise
