More than a Headache...
Old May 3, 2007 | 04:07 AM
03sonicgt's Avatar
03sonicgt
Default More than a Headache...
Alrighty guys, bear with me with this long thread, but I really need your guys's help...About 6 months ago, i started hearing a sqeaking noise from the back of the car, but when I pushed the brakes and the noise would seemingly go away. So I figured it was the brake pads, I changed those and got 4 new rotors. Even after the pads and rotors, the squeaking continued. I had the mechanic who did the brakes look and he wasn't sure what it is. Do you guys have any ideas what it could be? Here's the kicker, when it's raining outside it doesn't make the sqeaking noise from the rear. I'm thinking it might be a set of sticky rear calipers?? But could I have a messed up rear end, or a bad bearing in it or something?? Help me guys, this noise is ruining my car...
Old May 3, 2007 | 06:11 AM
cahtr6's Avatar
cahtr6
Default RE: More than a Headache...
I would put it up on alift somewhere so you can get under it while its running in gear to pinpoint the noise. Not quite as safe but jackstands could be used as well.
Old May 3, 2007 | 11:37 AM
undecided.steve's Avatar
undecided.steve
ORIGINAL: 03sonicgt
The rain part is your clue.
The rain is lubricating whatever is doing the squeeking.
I would get a can of spray silicon lubricant and spray all the rubber bushings on the sway bar, shocks, suspension etc.
Make sure to get it into the rubber real good.
Don't use regular oil because even though the rubber is oil resistant, oil will deteriorate the rubber anyway over time.
Give it a try.
Old May 3, 2007 | 11:38 AM
ackuric's Avatar
ackuric
theres no way to tell without replicating the situation when it occurs, pin-pointing exactly where the sounds coming from, only then can you hope to find out what it is. Could be your brake hardware wasnt changed out when they did your pads, could be a bushing in the rear, or exhaust squeeking against your body. So many possibilities.
Old May 3, 2007 | 12:06 PM
PaintballFreak's Avatar
PaintballFreak
yeah my bet is a suspension component that needs to be replaced or at least lubed
Old May 3, 2007 | 12:18 PM
03sonicgt's Avatar
03sonicgt
I've had the car on a lift, and it doesn't make the noise because there isn't any weight on the car's body, do you guys think I should just go to the dealer?
Vikefan88
Oct 12, 2007 10:13 AM
Verado
Sep 3, 2006 07:32 PM
