WHAT IS DRAINING MY BATTERY????
i have a 2002 gt and something drains my battery after a couple days.i pulled the fuses and found out its coming from the number 6 fuse i think it was, under the hood. and the book says its the instrument cluster/pcm. Does anyone have any ideas of where to look for this short that is killing my battery? thanks for any info you guys can give on this problem. thanks
make sure nothing is on (like an overhead light) when you leave your car and make sure ur battery is good! check the voltage with a voltmeter when the car is off, should be about 12 volts. and when the car is on should be about 14..my alternator went bad on mine about 6 months ago. it might be urs.
you might want to check it for codes....is it running alright? if it was a pcm shorting i would think youd be getting codes out the ****, cluster may even read inaccurate...how exactly did you determine the fuse thing?
Does your a/c work ? If not there is a relay in the inside passenger fender above the wheel well and it may be bad . I've seen several symptoms including yours and the a/c not working .I'm not sure what the part is called but it's mounted inside the fender near the engine compartment .
logan409
Sep 26, 2015 07:43 PM
