New flywheel
New flywheel
Just wondering but since im getting a new cobra crank do i need a cobra flywheel? If not will a cobra flywheel fit? because ill by this:
http://cgi.ebay.com/ebaymotors/1999-...18057387QQrdZ1
jimbo
jimbo
RE: New flywheel
I just check the kit i bought and it has a KELLOGG Forged 4340 Steel Crankshaft 8 bolt Cobra SO.... i guess this means i have to buy a new flywheel and it has to be a 8 bolt right? What size am i supposed to buy?
RE: New flywheel
ORIGINAL: JimboGT01
RE: New flywheel
well i just bought a 11in clutch kit so i need to get a rock hard answer about this topic. I'll need a 8 bolt flywheel, but do i need a 10.5 in clutch? What determines the size of the clutch you need?
jimbo
jimbo
RE: New flywheel
ORIGINAL: JimboGT01
jimbo
jimbo
RE: New flywheel
Yes, you do need an 8 bolt flywheel....steel or aluminum. Usually you can run either the 10.5 or 11" clutch. You will have to check with the maker of the flywheel to see if it is made to bolt up both sizes. FRPP has a aluminum flywheel that does accept both clutches. Another note........the stock flywheels are taped for metric bolts for the pressure plate. Make sure when purchasing an aftermarket one, to have the proper pressure plate mounting bolts.
Casey
Casey
RE: New flywheel
ORIGINAL: FDNYBullitt
I'll have to check my paperwork but I bought an 8 boltBillet SFI approved flywheel that is drilled for both clutches. A side question, are you putting this crank in a 2V block?
RE: New flywheel
The reason I asked is therewill be a crank clearance issue for the center counter-weights if its a Romeo block, but you may know this already. Some retailers state that the crank is a direct fit but it isn't, the center main bulkhead needs to be machined a bit on both sides for the crank to clear it, good luck. Also I remember now that I bought the flywheel from Steeda, 8 bolt, SFI approved and drilled and pinned for both 10 1/2 and 11" clutchs.
