ok, so i bought some Steeda Lowering springs, and it dropped my car pretty damn low.. When i drive it and go over bumps/ small dips in the road, the car seems to Bounce and have a "springy" feeling to it.. How can i stop this/fix it?[/align]
well everything is stock.. i got the springs for a good deal, and didnt know that i had to replace the shocks.. so what are some good shocks that i could buy that will fix the problem?
Keep in mind that when you get the bounce under control you'll probably have a very harsh ride. Lowering the car reduces the available suspension travel, however the weight of the car stays the same so the only way to keep things under control is to stiffen everything. [/align][/align]Your lowering springs have a higher spring rate than the OEM springs, and the only way to dampen the bounce is with "stiffer" shocks--all this = a harsher ride and that's just the way it is...[/align]
i put upr coilovers with tokino 5 way adjustable struts ( i only did the front, the back is still stock) and the ride quality has not changed for the worse.
Tokiko HP's work well too if dont want adjustables and dont want spend bucks on Bilstein's.Checkout some sponsers websites and look at pkg's with those springs.
