Compression?
Old May 6, 2007 | 12:23 PM
JayBanion's Avatar
JayBanion
Default Compression?
Ok my car has 127,000 miles and i want to do a compression test to make sure everythings good. My buddys got a tester. What should the compression be at, around 100psi, or more?
Old May 6, 2007 | 12:28 PM
DSTANG03's Avatar
DSTANG03
Default RE: Compression?
yes it should be around 110 or higher but what you want is every cyclinder to be within 5 psi of each other
Old May 6, 2007 | 12:33 PM
ackuric's Avatar
ackuric
DStang is wrong! You want the pressure to be within 4.2351901 Psi of eachother. =X
jp, Dstanger nailed it on the head =)
Old May 7, 2007 | 12:28 AM
JayBanion's Avatar
JayBanion
Just checked it, 7 out of 8 cylinders were at 160 psi, one was at 150. So am I good or should i be worried bout something.
Old May 7, 2007 | 01:42 AM
96GT226410's Avatar
96GT226410
CSMG Moderator
You're fine. Good numbers.
Old May 7, 2007 | 04:26 AM
FDNYBullitt's Avatar
FDNYBullitt
Those are very good #'s for the mileage thats on it. Seems like someone has been taking very good care of it, good luck.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
