Factory alarm and 4.10 questions
Hello everyone.
2 days ago I installed a Ford Racing 4.10 gear on my car, 98 mustang gt 5 spd... I went to the track and ran a best of 14.36, last year without the gear i ran a best of 14.42.. I'm spinning pretty good through 1st gear, whats the best way to solve my traction issues?
Also, my speedo is WAY off, how can I fix it?
Now for the factory alarm.
When I cought this car from the dealership, they somehow set that factory alarm and it worked. I would go to touch the door handle and the alarm would sound. Now, I could body clam the car and it wouldn't make a sound at all (I'd never actually do that, but just to give an idea). I can't figure out how to work it, the THEFT light always flashes no matter what, I can still lock and unlock the car with the keyless entry, but am not sure how to set the alarm. Does anyone know?
Thank you!
Thank you!
RE: Factory alarm and 4.10 questions
ORIGINAL: ba98mgt
Hello everyone.
Thank you!
Hello everyone.
Thank you!
And I don't know anything about the alarm, I don't even have power locks.
What do you think of the 4.10s with a T-45 by the way? I know 3.73s no a T-45 are about the same as 4.10s on a 3650, but after riding in my buddy's Terminator with nearly 600 RWHP, I want every bit of pull that I can get now!
Oh yeah, and for the speedo, you'll want to grab either a SpeedCal (http://www.americanmuscle.com/speed-...tor-94-04.html) or just get a tuner.
With a 98 you should be able to just replace the little plastic gear on the speedo pickup (its on the trans). You will have to buy a 4.10 gear and install it, shouldn't be that hard of a install but I don't have the mechanical trans so have never done it.
So far as traction, you have lots of options. The first thing I would try would be a set of drag radials. You can run a d/r like a nitto 555 R and get around 10K each out of them. With your power level a set of nittos should keep you from spinning pretty well.
If it still spins after the nittos the skys the limit, but starting mods on the suspension are springs, shocks/struts (adjustables are the best) and control arms.
I have no idea on the car alarm, mine didn't come with one.
thank you everyone!
So go with a set of DR's instead of ET Streets then? What size should I go with? My frineds told me to buy some cheap 15" rims becuase a set of 15's will let me fit more sidewall in the wheel well's... I can buy any size rims from the local yards for cheap... 15x8?
I love the 4.10's!!!! I kinda don't like the highway, at 70mph I was at roughly 2900 RPM
ORIGINAL: ba98mgt
thank you everyone!
thank you everyone!
i'll buy some crap rims to throw the DR's on... I will only use them at the track, and maybe a few times on the street, but thats maybe 3 times a year...
What size should i go with? i'm on the stock suspension.
Anyone with any input on the factory alarm thing?
09-10-2015 08:39 PM
