My b!tch is bleeding
rear main leak, was under the car today... oh well gotta do a clutch soon anyways [&:] 55k miles and it crapped on me. wondering if the underdrive pulleys and removing the dogbone had anything to do with it
RE: My b!tch is bleeding
Does your car use a lot of oil? I know I have an oil leak somewhere, but I don't want to remove the tranny again if I'm not almost positive it's the rear main seal because it takes too long in the driveway. I have to put in a quart about every 6-8 weeks I think. I'm guessing it is because rear mains are most notorious for oil leaks.
no I can get to the passenger side header and loosen all the bolts so I can swing the tranny out. Im leaking oil from the rear main, Its pretty noticable I can see the oil - probably a half quart per 3k miles.
Well, when stuff like that happens, it kinda gives you a good excuse to spend $ on upgrades cause it's cheaper to upgrade that part now since you need a new part installed anyway.
alright, two questions, what is the dog bone and how did you manage underdrives AND supercharger?
ORIGINAL: Fallstar01
