Does it not shake if you put it in neutral? I had a car in the past that had shot motor mounts and would shake when I pulled up to a light, but if I put it in neutral, it would not shake.
I dont think it is the motor mounts but what is this timing mount loose/bad thing? is that the gear bolted on the front of the cam on each cylender head?
