DO I NEED MILS
RE: DO I NEED MILS
Yes, the front 2 o2 sensors have to stay. yes, if someone has a tuner, you can clear the codes(only thing there good for on mutiple cars. The back 2 have to have the mils, unless you have a tuner. then just shut them off. No extensions arre needed unless you have long tubes........
RE: DO I NEED MILS
ORIGINAL: 96GTMustangCT
so when i go to switch the stock h pipe back on for emissions, what do i do with the mil eliminators
All stangs with an O/R midpipe need either MIL's or a tuner to turn off the rear O2 sensors. 04 GT's require extensions for the rear O2 sensors (18" for the passenger side, 4" for the driver's side). LT headers require extensions for the front O2 sensors as well.
I made my own MIL's, it cost me $6.15 in the end and it's been 820 miles or so and no CEL. Even if they fail, I can re-make them 10 times and it'll still cost me less than it would have to buy MIL's which would have failed multiple times in that time anyway.
RE: DO I NEED MILS
ORIGINAL: Jonny.GT
take them out, swap the pipe, smog, swap the pipe, put em back in XD
RE: DO I NEED MILS
so what if i dont use them, then the cel will stay on, i was told that i could go to advanced auto parts or a place like that and they can clear the code. will this work, how the heck do you make them yourself.
RE: DO I NEED MILS
You can clear the code and that'll fix it temporarily but it is just going to keep coming on over and over again.
Follow these instructions to make your own (courtesy of cliffyk here on MF)
http://paladinmicro.com/MyMustang/Mu...Eliminator.htm
Edit: Took me and a friend about an hour to make them + extensions. 850 miles or so so far and no CEL.
RE: DO I NEED MILS
RE: DO I NEED MILS
well i dont have time to make them and it seems like a pain in the butt to make them, im either going to buy them, or you said i can use a programmer. like a programmer for my year. i was wondering if i can find someone with one and use theirs. im just going to end up spending the frickin 60 bucks for them. im doin for racing shorties in the front so i shouldnt need extentions i should just need one pair for the back. thanks for all your help. and if anyone knows how to remove the quarter panel side scoop on a 96 gt please let me know. thanks
RE: DO I NEED MILS
You're correct otherwise, no need to do anything for the front O2 sensors, and a set of MIL's for the rear ones.
