Transmission problem?
RE: Transmission problem?
hmm then its probably the clutch going out.. if youre not throwing any codes i doubt its missing or something like that. i thought all transmissions had filters? see learn something everyday
ORIGINAL: 96GT226410
Are you leaking any engineoil?
Just took it out and dumped it in 4th gear, it bogged very fast then died. I only revved it to like 3k then did it. Tried to revv it higher the second time but I was in first do I just did a nice burnout then my apartments security came running out so I stopped.
Fuel filter was changed ~10k ago
Im no expert but shouldnt it be showing other symptoms if its the clutch? I mean ive never had any problems with it up until today. It still goes into gear fine and what not. On a side note...the traction control didnt kick on when i dumped the clutch at 4k in first.
ORIGINAL: 2002GTAUTOVERT
screw the security what are they going to say you cant find out if your clutch is going out? i say drop it in first at redline
They have a decibal level that all cars are supposed to be under while in the complex that Ive been warned about many times so I dont want to **** them off anymore.
