HELP DRIVING STICK
RE: HELP DRIVING STICK
Yup man they're all right, just practice. The concept is super simple, but applying it is difficult at first. "OMG what do I do!? People are pulling up at the stop sign going across the intersection I'm at...OMG OMG...PANIC!!! *stall*
Haha, good times.
Here's a lil somethin that will build up a lil feel for the clutch: Go to a wide open area, and drive in a straight line. Do not touch the gas. Just go through each gear slowly, letting the engine idle bring it up to speed each time.
Haha, good times.
ORIGINAL: 96GTMustangCT
yah i just hope im not hurtin her practicing on it ya know. just feel like sometimes the tranny is going to drop right out when im shifting from gear to gear, not used to the noises from a manual transmission and not used to the un-smooth shift yet. thats the biggest thing its just so frustrating
driving a stick is entertaining.
sit at a stoplight, put it in reverse, and just let off the clutch a wee bit with someone behind you. They FREAK OUT.
dont hit anyone of course, but try it, its amusing.
anyways some constructive advice.
if you think you ride the clutch too much, then find a road where you can make u turns every mile or so, and then just start and go start and go start and go. I did it in my old Mazda and it helped me stop riding the clutch and after 20 or so miles of the same stretch of road you end up with alot better of a feel for your trans.
Its not that hard, just time consuming.
Good luck
Good luck
everytime i down shift or what? just pop the clutch rev it a little in neutral and then throw it in gear?? see my dad was like here bought this for you. and its not stock its go cai, 3.73, short shifter, alot of other things in it so i dont wanna f*** anything up and he went out driving a few times with me but now i do ok. its just smooth through the gears and knowing what to do when downshifting and what not. thanks for all your help
Say im in 4th... if I wanna downshift what i'll do is shift into 3rd but before I let the clutch out I slightly rev it and as the repms go up just a bit I let off the clutch not too slow but not too fast. Now I basically do all that in one motion. It took me awhile to figure out what the hell I was doing but it seems to be working so far!
2010 Blue Ball Award Recipient
2K is usually a pretty good all around shift rpm, I learned on a car w/o a tach, and wish I had one when I learned.... Just shift, and let the clutch back out w/o gas... that should get rid of 90% of the 'jarring and jerking' you get between gears...
and if you start to feel yourself getting frustrated... give it a break for a bit,, when I'd just learned how to drive my car, i'd been dating my gf for like 2 months, and i'd take her out crusing,, start to get HORRIBLE jerks and stuff at launch and shifting gears,, i'd get so mad and things would just go downhill from there..
have fun with it, you probably wont break anything unless youre trying.. ;-)
Keep practicing and do not hot rod the car until you can drive it smoothly and normally to where it shifts like an automatic. Then once you get that down you can dog it a bit., but don't do it too early., good way to get into an accident or damage your car.
Here's a good trick, modulate the clutch using your ENTIRE leg, not just the ball of your foot. Your entire leg has to move with the clutch.
just started like a week ago. personally i think i do ok but i feel so nervous all the time. dont stall it muchbut im afraid of riding the clutch in first and feel as though through gears like 1-2 its a little more rough than id like. i know its a matter of time until i get it but im sure all you out there know pretty damn well how to drive stick. just thought if you had any suggestions that would help. thanks
