Engine Question
Old May 11, 2007 | 06:24 PM
mpeav3's Avatar
mpeav3
Default Engine Question
What all should I do to beef up my motor after I put my Procharger on, so I can turn up the boost and let her rip.
Old May 11, 2007 | 06:25 PM
lizzyfan's Avatar
lizzyfan
Underboss
Default RE: Engine Question
Get a new shortblock[8D]
Old May 11, 2007 | 06:40 PM
97stanger's Avatar
97stanger
MMR900 shortblock and call it a day
Old May 11, 2007 | 06:42 PM
mpeav3's Avatar
mpeav3
What is all included in these kits??
Old May 11, 2007 | 06:43 PM
NeoTokyo's Avatar
NeoTokyo
+1 shortblock
Old May 11, 2007 | 06:50 PM
ponysnake99's Avatar
ponysnake99
MMR 4.6 Street Mod 900 (up to 900HP)
*Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed
*New 4340 Forged 3.543 stroke Cobra Crankshaft w/micro polished journals at no extra charge
*New 4340 5.933 Manley H-beam Rods w/ARP rod bolts ( These US made rods are shotpeened, magnafluxed and weight matched to bring you the finest H-beam rod available for your 4.6
*New Forged Manley pistons 3.552 Bore size (High or low compression)
*Speed Pro file fit rings (precision file fit to your application, nitrous, blower, turbo or N/A)
*Speed Pro/Federal Mogul tri-metal Rod and Main bearings
*Complete Pro Assembly and Balancing for the smoothest, highest revving shortblock available.
Shortblock Options:
Coated Pistons (ceramic dome/teflon skirt) $399.99
Brand New Current production Aluminum Block +$699.99 for NA or $729 S/C Blocks
ARP 2000 Rod Bolt Upgrade (recommended for 900+HP) $99.99
ARP Mainstuds (recommended for 600+HP) +169.99
MMR Street/Racing Oil Pump (highly recommended) + $199.99
ARP Headstuds and MMR/Felpro Extreme Duty Headgaskets + $369.99
MMR windage tray and hardware kit (+15HP) + 129.99
http://www.modularmustangracing.com/...hortblocks.htm
Old May 11, 2007 | 06:52 PM
mpeav3's Avatar
mpeav3
So, this would be all I need to crank up the power? And also will I need a dyno tune with this?
Old May 11, 2007 | 11:01 PM
Xemeth's Avatar
Xemeth
ORIGINAL: mpeav3
Well, how's the rest of your car? No use in making 900 hp with the engine if the tranny and rear end blow. You can rev the engine all you want, just won't go anywhere. Can't forget the drivetrain when making a lot of power. Gotta upgrade the suspension to get that power to the ground, too.
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
