Help on install!! please help
could i install my tachometer to my 03 mustang with this GMR pickup does anyone know?
Just think of things you can easily accomplish with our GMR Pick-Up! This little device simply attaches, no splicing or cutting, to a current carrying wire and turns that information into a 12-volt rpm signal. This signal can be used to activate a shift light, rpm activation switch or a tachometer.
One example is on an engine equipped with a coil-onplug ignition system. One of the coil’s primary current wires is simply routed into the pickup clip and the GMR converts this pulsing into a 12 volt square wave to trigger a shift light or tachometer.
09-10-2015 08:39 PM
