AT question
AT question
I went to check all the fluids the other day and notice the trans fluid was a bit low. Now here the dumb question... Where on the stick is it supposed to be when its full? I tried it without it running and it seems to cover the whole end of the stick, but when its running (and been running for around an hour), only between C and H.
Thank you in advance.
RE: AT question
You always check the trans fluid when the car is running. You want to chaeck it when its hot. Drive the car a few miles to make sure its up to full operating temp, then give it a check. You want to check the fluid when its hot because trans fluid will expand.
The marks on the dipstick are H for hot, C when cold. If you're between the hot and cold fill lines you should be ok, but you might want to add a little to get it up to the line when hot.
RE: AT question
ORIGINAL: hotrod7687
...If you're between the hot and cold fill lines you should be ok, but you might want to add a little to get it up to the line when hot.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
