welds on my 2002 gt
RE: welds on my 2002 gt
i hope so...i just ordered some haha...but i talked to a few people that have them and they never mentioned doing that...atleast for the rear...i think one guy told me i would have to shave down the caliper or something...but im oretty sure the rear will fit fine
The rear 15x8 welds need to have a 5.5 inch backspace an the 15 x10 need 6.5 BS....The front 15 x3 1/2..(skinnies) need at least a 7/16 wheel spacerand you will need to grind the caliper Bracket flat(not much really),,so it doesn't rub the rim on the inside.....
ORIGINAL: 8banger
.Mine very gently rubbed on the bracket....hence the grind...alo was told by several,,may or may not need to grind.with a 1/2 inch spacer....wouldnt touch at all....but ,,the 7/16 spacers where free........
7/16's is safer alsobecuase you get 9 full turn of the lugnuts with stock length studs.
ORIGINAL: 8banger
ORIGINAL: 01GT4.6
true.... for the most part. You don't need to gring the calipers bracket with a 7/16" spacer, or atleast I didn't have to. And to answer the original question, if you have stock GT brakes you are fine.
ORIGINAL: 8banger
Me either, but the back of the wheel is super close. No rubbing tho.
09-17-2015 07:57 PM
