Injectors???
Injectors???
What is the difference in fuel injectors for my car, I know what they do, but how will bigger ones help me? I understand that i will need to get a diablosport predator or hypertech to change my computer, but how would this do me good?
RE: Injectors???
If your fuel demand is overloaded... ex: supercharger or over 500hp, you would want larger injectors so the fuel supply is sufficent! This helps maintain a proper A/F. But your mods (the ones listed) should not require larger injectors. A tune or a Flash tuner would help more.
RE: Injectors???
what do you mean tune or flash tune? I bought a Pro-M MAF that is calibrated to 24# Injectors which i have in my car stock. The MAF also came with Ford Racing 24# High Performance Injectors, are these any different from the stock ones i have? So do you think I should get the MAF re-calibrated and get bigger Injectors, or just leave it as it is? would bigger Injectors give me more HP?
RE: Injectors???
Just leave it stock.
Tune = Dyno tune... by a professional
Flash Tune = Hypertech, Superchips, Diablo Sport, etc. They plug into the OBD II port and change some computer settings to give you more power. A dyno tune is still better!
As of right now, if you use bigger injectors you will lose power! So leave it be
